mazda speedi3 2010
Old Aug 20, 2009 | 03:03 PM
nandy Pungyan's Avatar
Default mazda speedi3 2010
technical specs:
Standard Engine________________________ 2.3L I4
Standard Transmission___________________ 6 Speed Manual
Cylinders ______________________________4
Horsepower @RPM______________________ 263@5500
Fuel Economy Cty/Hwy__________________ 18 / 25
Combined Fuel Economy _________________21
EPA Class _____________________________Mid-Size
Number of Valves_______________________16
Torque @RPM _________________________ N/A
Fuel Type System ______________________Gas Engine / Electronic Fuel Injected
Turbo (Yes/No) ________________________Yes
Overdrive Transmission __________________Yes
Battery Output ________________________ N/A
Compression ___________________________9.5:1
Displacement __________________________2260 / 138
Bore X Stroke _________________________3.44x3.70
Cruising Range ________________________ 333.9 miles
Final Drive Gear Ratio Opt ________________N/A
Power to Weight Ratio ___________________12.3
Final Drive Ratio _________________________Yes
Valves Configuration _____________________Dual Overhead Cam / Twin Overhead Cam
Supercharged __________________________ No
Electric Horse Power RPM _________________N/A
Electric Torque Feet Per Pound ____________N/A (foot-lbs)
Electric Torque RPM _____________________N/A
Electric Horse Power BHP _________________ N/A
anti thief and lock
  • Child Safety Door Locks Located On Rear Doors
  • Vehicle Anti-Theft Via Engine Immobilizer
  • Selective Locking/Unlocking
  • Power Door Locks Operated Via Remote and Internal Switch With Automatic Locking
brake and traction
  • Front Power 320-mm Ventilated Disc and Rear Power 280-mm Solid Disc Brakes
  • Traction Control
  • Dynamic Stability Control (DSC) Vehicle Stability Control System
  • 4-Wheel Anti-Lock Brakes
  • Electronic Brake Force Distribution
  • Limited Slip Differential
  • Electronic Brake Assistance
instrumentation
  • Tachometer
  • Exterior Temperature Gauge
  • Maintenance Interval Indicator
  • Cruise Control
  • Tire Pressure Monitor
  • Digital Clock
  • Steering Wheel Mounted Controls For Audio and Cruise Control
  • Warning Lights Include Brake System, Door Ajar, Electrical System, Oil Pressure and Low Fuel
  • Electroluminescent Instrumentation
safety
  • Front Pretensioners With Force Limiters
  • L A T C H
  • Passenger Airbag Cutoff Sensor Activated By Passenger Weight
  • Automatic Locking Retractors
  • Front and Rear Side Head Curtain Airbags
  • Side Guard Door Beams
  • Driver Airbag With Dual Stage Deployment
  • Front Seatbelt Height Adjusters
  • Front and Rear Crumple Zones
  • Front and Rear 3-Point Seatbelts
  • Front Active Head Restraints
  • Seat Mounted Front Side Airbags
  • Rear 3-Point Center Seatbelt
  • Passenger Airbag With Dual Stage Deployment
steering
  • Tilt Steering Column
  • Telescopic Steering Column
  • Power Speed Sensing Rack and Pinion Variable Assisted Steering
exterior dimension and weight
Curb Weight MT:
3245
Curb Weight AT: N/A
Ground Clearance: 4.7
Height : 57.5
Length : 177.6
Top Type (Standard): Hard Fixed
Top Type (Optional) N/A
Track (Front) 60.4 Track (Rear) 60.0
Weight Distribution AT (Front) N/A
Weight Distribution AT (Rear) N/A
Weight Distribution MT (Front) 60
Weight Distribution MT (Rear) 40
Wheelbase 103.9
Width 69.7 Doors (Standard) 4 Doors (Maximum) 4
Attached Thumbnails mazda speedi3 2010-mazda_mazdaspeed3_sport_5_door_2010.jpg
Old Aug 20, 2009 | 04:15 PM
apbbnbanb_07's Avatar
This guy is really getting on my nerves.
There is a reason Mazda has their own website for crap like this.
Old Aug 21, 2009 | 09:20 AM
Aubrey's Avatar
Man, I thought you were going to stop posting crap like this. You appologized on a couple of other useless posts. You are annoying.
intoo
May 5, 2015 11:33 AM
intoo
May 5, 2015 11:32 AM
Aubrey
Oct 19, 2010 08:18 PM
mazdawanter
Aug 23, 2008 10:56 AM
abupu
Jun 13, 2008 03:12 PM
