Knock sensor and eating oil problem
Old Apr 8, 2015 | 03:47 AM
Markus Hlevnjakus's Avatar
Default Knock sensor and eating oil problem
Hi all,
does anybody knows is there some connection between broken knock sensor and engine burning oil?
My engine light turned on and diagnostics said that there is some error with knock sensor. I haven't fixed it yet because my mechanic said not to worry about that(engine light goes off when I start the car for the fourth time and goes on again if car is not started for some period of time, for example overnight). Then I noticed that my car is burning oil ( 1l per 1000-1200km). There is no oil spot on the ground. Can broken knock sensor cause that or my car is burning oil because of something else? Do anybody have any idea what can cause oil burning?
Car is:
Mazda 3 sport 1.4, 85HP, 106000km, year 2004.
Old Apr 8, 2015 | 07:27 AM
Snowflak3's Avatar
1 liter of oil burning off per 1100km? that's uh... about a quart in 750-ish miles (in ye olden english).
That's a lot of oil. Burning off a quart of oil between changes is normal enough. But not an entire crankcase full.
A faulty knock sensor won't cause you to burn oil. But I do suspect you have an engine problem which is causing excessive oil burning, and possibly making your knock sensor unhappy.
Old Dec 26, 2025 | 04:49 PM
motherbex@outlook.com's Avatar
Default Same!
Hi, I realise this is ten years on but I'm wondering if you ever found out what the issue was, as mine is doing the exact same thing!?!... I'm hoping you can remember!
Old Dec 26, 2025 | 06:59 PM
If you looked neither member has been on , one since 2015 and the other 2016 as a new member you may be better off to start a new thread introduce yourself and give your exact issue question and all your Mazda Information ?
legepe
Jan 11, 2025 03:59 AM
edscx-9
Dec 31, 2022 09:48 AM
Alo
Sep 25, 2021 07:44 PM
duckofalltrades
Oct 10, 2013 03:52 PM
onewei364
Jan 25, 2007 03:04 PM
