Key Fob Horn Alert
Old Oct 13, 2008 | 08:17 AM
Hit The Road Jack's Avatar
Default Key Fob Horn Alert
Hello all!
My wifes 2004 5-door Mazda 3 has developed an intermittent problem with the emergency alert and lock door alert function, found on her key fob.Sometimes the horn toots, sometimes it does'nt.
TIA for your response...Jack
Old Oct 13, 2008 | 02:30 PM
Default RE: Key Fob Horn Alert
Hey Jack! Welcome....
I can think of three things it might (or might not) be offhand:
1) If all the doors and hatch are not closed properly, or is not being detected as being fully closed, the horn will not sound.
2) The horn itself, wiring or connections are faulty
3) The horn relay is on the fritz.
These last two should be easy to check by just using the horn from the steering wheel.
4) I just thought of this one: How is the battery in the remote?? I don"t know for sure, but it could be a warning to replace the battery??
Old Oct 13, 2008 | 04:41 PM
icspots's Avatar
^^ +1 to everything Richard just said.
Old Oct 14, 2008 | 07:56 AM
ORIGINAL: virgin1
Thank you virgin1for the reply!
Narrowing it down I think #4 might be the culprit, all the doors having to be shut tightwas myfirst troubleshoot.
When the horn does'nt toot the signal lights also intermittently do'nt light, so it probably is'nt the horn connection, also the horn does toot from the steering wheel.
I will try replacing the key fob battery, although the second key fob creates the same problem.
Regards,
Jack
Old Oct 14, 2008 | 09:37 AM
icspots's Avatar
I suppose it could also be a problem with the remote system itself.
Old Oct 14, 2008 | 02:44 PM
Hmmm? I"m sorry to hear that. That"s not promising.
Well, here"s an oldie but a goodie! Whenall else fails, try resetting the PCM/ECU!
If you don"t know how, it"s easy.
Disconnect the two battery cables (10mm wrench.) Hold them together (+ plus -) for @ least 30secs and reconnect.
You will lose your radio settings, trip mileage, cruise "on" setting and clock, so you may want to make a note of all that stuff and reset it when you are done.
It"s worth a try. And, what can it hurt?
Old Nov 20, 2008 | 06:12 AM
Hi Virgin1,
The problem had stopped after getting rear ended at a stop sign a while back(@5 MPH) no biggy. Last night DW told me it happened again.
Old Nov 20, 2008 | 07:36 AM
icspots's Avatar
ORIGINAL: Hit The Road Jack
Hi Virgin1,
Well I wouldn't normally suggest that as a means to fix a remote problem, but if it works...... :P
Old Nov 20, 2008 | 01:23 PM
jaimie08mazda3's Avatar
well hey if you get rear ended and it fixes a problem. then say thank you to the guy that hit you lol
Old Nov 20, 2008 | 05:13 PM
Yes, if it weren"t so sad, it would be funny!!
I think you"ve got us stumped, and it could be time for a trip to the dealer, or at least a friendly call about it. Perhaps they have heard of this and have an easy fix you might do yourself?
