Jacking point issue
What ho one and all,
Assuming I want to do something to one of the wheel hubs, brakes (whatever), can use my trolley jack to lift the car using the jacking point. I do have some slotted timber to protect and spread the load. But I also want to support with an axle stand, which should be positioned at the the jacking point, but that position is currently occupied with the trolley jack.
So where is a good position to lift the car prior to lowering onto the axle stand?
Thanks
Thanks
The strongest areas would be the sub frames that attach the control arms (front and rear) .
There may be other parts in the way, and you may not get a good angle for the jack. Just use common sense and be careful.
Will have a look the next time I have it on the ramps. On my previous car, I usually used the cup on the jack over one of the sub-frame mounting bolts for the temporary lift until I could get the axle stand into position.
