Hooking up LED strips in 2010 mazda 3 sport
Old Apr 5, 2011 | 11:07 PM
goodolmatty's Avatar
Default Hooking up LED strips in 2010 mazda 3 sport
I am looking to hook up some blue LED strips into my 2010 mazda 3 sport. possibly under my door or by peoples feet. I would like them to turn on like the dome lights do (everytime i open a door). I cannot find a door sensor and do not want to pull and prode at every wire i see. Can someone tell me instructions on where i may find a wire that leads to the domelights or to the sensor in the door which tells the lights that a door is open?
Old Apr 7, 2011 | 01:36 AM
cornwellbs's Avatar
so you just want them to come on when the door is opened then go back off when the door is closed??
Old Apr 8, 2011 | 09:53 AM
icspots's Avatar
Try using the wires noted in this install of the JDM footwell lamps on the 1st gen. Assuming that works then your lights will come on: when you unlock the doors via the remote, when you open a door, or when you turn off the ignition. They'll turn off when you: turn the ignition to ACC, lock the doors via the remote, or about 30 seconds after the last time a door was closed and not locked.
Bear in mind that the dome lights are a constant 12v and a switched ground. Just FYI.
UseYourNoggin
Oct 23, 2012 10:27 AM
jaimie08mazda3
Jan 31, 2012 08:15 AM
Syphorus
Jul 21, 2011 04:32 AM
mpvowner
Mar 22, 2011 09:29 AM
fdsailor
Mar 22, 2011 08:06 AM
