help with my 93 626
Old Dec 6, 2009 | 11:05 PM
gami892's Avatar
Default help with my 93 626
hi people im new to this forum. i need some help with my 1993 mazda 626 2.0 . the only way i can start this car is by holding down the gas pedal and when it starts shes fine but! the rpms on the cluster show a very high idle speed of 1500 i have checked and found no vacum leaks. do you guys have any ideas wats going on. i have change fuel and air filter and also plugs and distributor and still have the same problem...
Old Dec 6, 2009 | 11:12 PM
wsoape281's Avatar
having to hold the gas pedal down to start it sounds like either a fuel pressure issue or jumped timing. high idle, i am not sure.
Old Dec 7, 2009 | 03:00 PM
ProfessorDave's Avatar
I had chronic EGR valve problems on a 94 626 years back. Created starting and idle problems, although not exactly as you described. Still, might be worth checking.
Ms626
Oct 3, 2010 07:33 AM
626v6
Apr 22, 2010 09:00 PM
blan
May 13, 2008 12:15 PM
NewGuy181
May 14, 2006 03:44 PM
doormizzles
Apr 2, 2006 09:16 PM
