Help identify this broken part
Old Aug 31, 2019 | 04:22 PM
Davlafont's Avatar
Default Help identify this broken part
2010 Mazda 3, 2.5l 6-speed manual, probably Grand Touring package. (HID headlights with AFS, leather seats.)
What is this small ball-joint end attached to my left/driver side lower control arm? The bracket attaching it the the control arm isn’t very beefy so it’s not meant to handle much load. The piece is aluminum and the bushing is plastic/nylon.
Thanks in advnce
Old Sep 2, 2019 | 06:41 AM
I would say its the remains of your ride height sensor for the AFS.
Old Sep 2, 2019 | 08:28 AM
Davlafont's Avatar
Thanks Grim. That makes sense, I just wish I could find the other half. Any idea how long the original strut is/was? It probably routes behind the plastic shrouding, right? There’s nothing in the wheel well area.
I also have these wires dangling nearby, coming from behind the plastic:
Old Sep 3, 2019 | 03:18 AM
I sugest contacting some Mazda Wreckers for a complete sensor setup plus 6 inches of wiring loom to splice in.
Old Sep 26, 2019 | 05:45 AM
Davlafont's Avatar
Grim_reaper, you were right on the money: AFS ride height sensor assembly. It took a bit of time, but I tracked down a replacement:
Came with complete wiring harness, so no splicing required!
My problem now is fabricating a bracket. Whatever the sensor mounted to seems to be gone and I have no example to go by. I’ve asked for photo assistance in another forum (in the MS3 section since AFS is more prevalent on the Speed 3); zero response. Maybe I’ll start a new thread here too.
Old Sep 30, 2019 | 05:30 PM
Davlafont's Avatar
Well, in the interest of completing the record on this for any future searches, I removed the potentiometer/sensor from the brackets and plugged it into the vehicle harness. That has silenced the blinking dashboard warning light and restored the sideways pointing feature of the AFS headlights. I suppose it means the lights will not adjust for angle of pitch—like 90% of all cars on the road don’t. Or, it’s possible that the rear sensor will signal something that the front sensor doesn’t (because it’s tucked away disconnected) and the lights will briefly angle in a way that’s not needed or desired. I’ll keep a look out for that.
Old Sep 14, 2023 | 09:17 AM
ron.wenger05@gmail.com's Avatar
Default Ride Height Sensor (Level Sensor)
After replacing the part, did it require any calibration?
Monkeyboyrock
May 16, 2023 12:51 PM
siego99344
Mar 29, 2019 11:54 AM
toplessFC3Sman
May 9, 2016 11:43 AM
xeromossyoak
Oct 21, 2007 10:06 PM
zoomzoomwannabe
13
Feb 11, 2007 01:30 PM
