getting some kind of noise when music is louder
Old Sep 29, 2007 | 09:52 PM
jaimie08mazda3's Avatar
Default getting some kind of noise when music is louder
ok so im driving and have my music loud. and i hear this kind of crackling noise. now first off i think its the speaker. buti check the speakers. they are perfectly fine. so i keep on driving and it does it again. soo i hold my hand against the inside of the passenger door and it stops. so im wondering if maybe the inside of it is loose or something or there is something thats rattling in there. what do you guys think.
Old Sep 29, 2007 | 10:05 PM
Lupae3s's Avatar
Default RE: getting some kind of noise when music is louder
is the noise static of some sort???
and sometimes i get noises out of my speakers that isnt music. for example, when i use my turn signal i can hear it clicking on and off through the speakers due to electromagnetic pulses. cell phones are also known to interfere with electronic signals.
Old Sep 29, 2007 | 10:13 PM
hmmm that may be actually the reason. cuz yea its a little crackling staticy noise. hmmm could be my cellphone as i have it in my car every day.
Old Sep 29, 2007 | 10:35 PM
krimsonviper's Avatar
Does it happen when your cell phone is about to go active, or does it only happen when you turn the music way up? Is it periodic? You can check the wires if its constant to see if its grounding out. Do you have the bose system? If so, it might be the amp
Old Sep 30, 2007 | 04:36 AM
There has also been an issue with the drains @ the bottom of the doors that causes a rattling when the music is loud.
The water drains have little plastic trapped doorsover them, one-way valves if you will, that are known to be a problem. Remove, or temporarily tape them down to see if that's what the problem is. If it turns out that that's it, remove them altogether. It shouldn't hurt anything, just make sure they're clear of debris every once in a while.
Old Sep 30, 2007 | 04:40 AM
ORIGINAL: Lupae3s
... cell phones are also known to interfere with electronic signals.
Yeah. Driving ability too.
Old Sep 30, 2007 | 05:22 AM
haha well virgin you may have something there. i will check that today. because i am sure its not my speakers but something inside my door panel. and yes using a cellphone interferes with your driving abilities... thats why i dont use it while driving.... well most of the time XD. anyway people i am off to work have a good one. ciao
Old Oct 1, 2007 | 09:10 AM
LordChrisofSith's Avatar
I have that same crackling noise in my car as well. It does go away when you push on the door panel. It sounds like static, like a loose connection on the speaker. I don't want to break any clips holding the door panel so I have just left it as is. Musis is not that loud. Happens around 12 to 15 or higher. Happend in the r/s mostly. Then now the left side. I will keep my eye on this thread cause I don't want to take it to the dealer for ahwile. I was going to try that loop record thing people are talking about, but I really should not have too. Is there a way to check the speaker without taking the whole panel off. Like the round cover, does that just come off. I have not had a close enough look.
Old Oct 1, 2007 | 09:32 AM
yea thats the same problem and at the exact same time. i am wanting to go to the stealership but im not too sure really yet. if its a simple problem then it is kind of pointless.
dieseldriver2003
May 14, 2012 04:31 PM
kevinlamar
Jun 29, 2008 07:22 PM
dlheck
Nov 27, 2006 01:05 PM
esloyer
Sep 4, 2006 07:31 PM
Alucard
Feb 23, 2006 02:05 AM
