Check Engine Light and Code po 456
Old Apr 24, 2024 | 01:46 PM
Tippy's Avatar
Default Check Engine Light and Code po 456
No noticeable symptoms for this 2013 (edited to delete 2015) Mazda 3 four-door sedan yet the engine light stays on. Supposedly some type of fuel or fuel vapor leak. I have changed gas cap as cheap, but light has not gone off after driving about 10 miles. Anything else owner can check easily? What is usually wrong when you get this code; Advance Auto ran the scanner for me.
Old Apr 24, 2024 | 04:20 PM
Welcome to the forum.
You need to have it properly scanned . Not saying that Advance Auto didn't do it correctly they just apparently did not give you all the information. Then post the codes found in all area's of your ECU not just the one. and also if any of the I/M files (monitors) are not complete or in state of readiness
Also like a service shop please post all the details about your vehicle.
miles
Transmission type
Last type of service done and date and miles
BTW it takes more then 10 miles (not sure where you got that information?) with some condition that caused a DTC before it will clear and turn off the dash light. 1-3 or more complete drive cycles depending on what the DTC where to begin with.
DO NOT randomly replace parts without first always confirming that they are the cause of the problem. Often they will create more issues then the original unresolved ones!
Old Apr 24, 2024 | 04:56 PM
Tippy's Avatar
miles
Transmission type
AA claimed no other codes and provided 10-100 miles. I've read drive cycles is the key so maybe a few days unless I get it cleared.
Last Service: 3 weeks ago, oil change; 3 months ago forced by mandatory inspection to replace rear reflector (tiny crack) and anti sway bars.
Mileage: ~61,000
Transmission: 5 speed manual
I think it is the smaller 4 cylinder engine (my SIL's car).
I don't normally replace parts without a definitive cause, but this gas cap a whole lot cheaper than paying for diagnostics. If it doesn't work, no harm and still can get diagnostics. Per SIL, the engine light has never lit up as an alert before. So I am still looking for things to check before I go for diagnostics. Apparently, if this code holds true, then a mechanic would use smoke to detect the leak.
Old Apr 24, 2024 | 05:38 PM
Thank you for a complete answer. Advance Auto generally does not have the few real ASE's do parking lot scanning unless they are training an employee. They are generally managers or district managers. The test done from them for free is basically just what you would get for free. Not knocking AA I just know some chain auto parts store very well.
The service you provided is good to know. Hopefully the cause was not something accidently damaged from the oil filter service?
Drive it a few days as I recommended . If the light remain you should get a shop that has an ASE sign on their building. At least you can hope you get real Tech to run a complete Diagnostic scan for you. It only take about 5 minutes from removing the scanning from the case plugging it in run the scan and putting it back in its case. .
ASE
Old Apr 24, 2024 | 06:15 PM
Tippy's Avatar
Many thanks for the good advice.
Ishfaaq
Jun 13, 2021 09:53 AM
wdjones
May 21, 2010 12:11 PM
jothmg
Nov 12, 2007 04:46 PM
hottsy7
Oct 20, 2006 06:35 AM
danmbruck
May 24, 2006 01:12 PM
