Car Won't Start -- Help!
Old Sep 6, 2018 | 11:30 AM
ChrisN's Avatar
Default Car Won't Start -- Help!
Hi All,
I'm the 2nd owner of a Mazda 3 2013 with about 59,500 miles on it. I love it! And it runs well, but I've had an issue and can't seem to pinpoint the exact problem. So here's the problem: sometimes my car won't start when I turn it on - it will crank or turnover (I'm not sure what the exact terminology is) but it won't start. I've noticed this happen under the following circumstance: when I've driven it to school and parked in the underground lot (or above ground lot) for hours - usually about 11 hours. But for some reason, it hasn't done it when I turn my car on the morning (only once I think). During the summer, when I parked my car outside for about 9-10 hours there would be no issue turning it on. Second thing I noticed is that when I've hit the gas WHILE turning on the car a second time after it didn't start the first time, it starts up fine. I figured it was a fuel issue so I took it to my mechanic this past week and they cleaned out the throttle and changed the cabin filter. However, once again, last night, when I was at school for about 10 hours, it did the same thing where it didn't turn on the first try. (Side note: if relevant, no check engine light on)
Before I start racking up expenses on trying to figure out the issue, I wanted to see if any of you had any feedback you could provide me with! A couple things about my maintenance: I do its routine oil changes and have also had the tranny fluid drained and filled because I was told by my mechanic that the color was very, very dark, and now this week had the throttle body cleaned out.
I appreciate your feedback!! Thanks
cassey005
Jan 9, 2015 09:07 AM
94protege8721
Mar 7, 2009 06:07 PM
jmw23712
Dec 17, 2007 02:58 PM
STARBUCK
Mar 8, 2007 07:17 PM
dborten
Nov 29, 2006 07:16 PM
