can a 2.0l motor be put in a car that currently has a 2.3l?
Old Aug 27, 2008 | 02:04 PM
xflashjr's Avatar
Default can a 2.0l motor be put in a car that currently has a 2.3l?
Hey everyone, this is my first post on this forum. I am actually a vendor on many other car forums and know the scene very well. I wanted to make that known before I get flamed for wanting to put a smaller motor in my car! I realy do not need any comments trying to convince me to not do this.
Here is some background info. My younger brother just turned 17 and wanted a mazda 3, unfortunatly the car was out of the price range my parents wanted to spend for a first car so I kept my eye out for a good deal. I just picked up a 2005 mazda 3 four door with the 2.3l motor. The car is fully loaded but does have a reconstructed title. This does not scare me and after checking out the body on a rack, everything is straight and all repairs were done within specs. unfortuantly the motor had some issues and the previous owner threw a rod, and the car has been parked ever since.
I ended up purchasing a used 2.0l motor with 30k miles on it, without doing much research, because I got the motor for next to nothing and I had to make a decision shortly after I found it. After picking the car up I relized the car is the S model with the larger 2.3l engine. My brother will not care if the car has the 2.0l or 2.3l in it, and my parents would actually prefer a less powerful car for him. I do not care about resale value on this car as he will drive this car until it dies.
Since the old block is not salvageable at all (piston knocked a hole in it) I wanted to see if putting the 2.0l in would be a direct swap? The only issues I thought I might run into is possibly the 2.3l transmission (Am not sure if they are different at all) and the possibility of needing a 2.0l ECU to make everything run correctly.
Can someone let me know what problems I might run in to? If the only issues in the ECU I am not worried in the least, if the transmission is completly different (I doubt it) then that might throw a wrench in the procedure.
I also assume that the 2.0l and 2.3l use the same block, and the larger motor is just bored and stroked to achieve the larger displacement? If this is the case then will all of the motor mounts match up to both engines?
Thank you everyone for taking the time to help me out, I greatly appreciate it.
Steve
Old Aug 27, 2008 | 03:14 PM
Default RE: can a 2.0l motor be put in a car that currently has a 2.3l?
Well, I've not heard of this being done before, but some of your concerns seem correct.
The 2.0and 2.3 share the same bore/different stroke. I would "think" they would interchange, but the correct ECU is a must, I'm sure. They are not exactly the same engine though. The 2.3 has VVT, the early 2.0's did not. The intake manifolds are different too and I do not know if they are a direct fit to each other.
I would think the important sensors are the same but the fuel map will surly be different.
Old Aug 30, 2008 | 05:47 PM
Mazdatkb's Avatar
You didn't mention whether the transmission is a manual or an automatic. If it's a manual there should be little trouble. However if it's an automatic, the 2.3L uses the 5 speed auto while the 2.0L uses a 4 speed. I think that was true for the 05s as well as the newer versions but you should make sure of that (I've been known to be wrong from time-to-time). Regardless, since you're doing a major transplant anyway, the correct trans should be available at a salvage yard for low bucks. While there why not pull the ecu from a 2.0L car and avoid the chance of a mismatch.
Nice thing you're doing for your brother - best of luck with the project. Keep us posted on your progress.
Old Aug 30, 2008 | 06:16 PM
No. In 04-05-06 they used the 4-sp ATX. It should work and be OK.
Kram Yelooc
Aug 30, 2013 04:39 PM
browntown3
Jul 9, 2009 03:41 PM
Bimmerista
May 8, 2009 02:58 AM
virgin1
Dec 17, 2007 09:54 AM
