Cabin Air Filter
Old Jun 15, 2008 | 08:41 PM
MrSpike118's Avatar
Default Cabin Air Filter
So does the 3 have a cabin air filter? I always see conflicting reports and just want to get to the bottom of this. My 6 did, but I need to know if the 3 does. Thanks in advance!
Brandon
Old Jun 16, 2008 | 10:15 AM
wineye's Avatar
Default RE: Cabin Air Filter
yes it does.
________
Prettylady4U Live
Old Jun 16, 2008 | 03:51 PM
'03(Europe/Asia/Australia)-'04's did not. They can be retrofitted.
Old Jun 16, 2008 | 05:35 PM
MrSpike118's Avatar
So Virgin, I am guessing it is in the same spot as the 6's then? Acess it through the glove box, and remove the cover?
Old Jun 16, 2008 | 05:43 PM
It is under the RS console cover from pics I've seen, but I don't have one. Figured, I'd lived this long w/o one, why would I spend (+/-) $40 a year on a new one.
Old Jun 16, 2008 | 05:45 PM
MrSpike118's Avatar
RS console cover?
Old Jun 16, 2008 | 05:46 PM
Siber Express's Avatar
I actually Googled it last night and there was a couple of diffenet articals to change it.
Old Jun 19, 2008 | 12:00 AM
woodurb69's Avatar
the mazda 3 does have a cabinair filter. it is located on the pass side on the air box located under the dash. you should pull the glove box out(for visibility). pull the fuse box down & disconnect its connectors & remove it. you should then removed the fuse box bracket (two 12mm nuts) & then on the air box you will see a cover right next to where the bracket was placed that has 3 or four phillips head screws. removed the screws pop the cover & they are inside one below the other. pull the bottom one & the top one will fall down. reverse & repeat
Old Jun 19, 2008 | 12:25 PM
Fritz T Coyote's Avatar
ORIGINAL: woodurb69
That was really thoughtful of the engineers to put this common maintenance item in such a convenient location.
Old Jun 19, 2008 | 02:45 PM
That's one reason I'm glad mine doesn't have one.
So let me get this straight, woodurb, the cabin filter is located beneath the glove compartment under (above actually) that kick panel, or is it inside the base (forward) of the console, underneath the HVAC controls, which is where I always thought it was? Don't you have to remove the RS kick panel of the console to access it?
andy936867
Oct 20, 2007 04:10 AM
PHILIP
Apr 9, 2007 07:28 PM
susa
Mar 28, 2007 02:24 PM
frncscchavez
Feb 11, 2007 12:10 AM
jvpoirier
Sep 25, 2006 11:54 PM
