Bose Stereo Questions
Old Nov 6, 2025 | 12:36 PM
Enduros5's Avatar
Default Bose Stereo Questions
Hello all!
I've been searching for answers on this and thus far haven't found much.
I have a 2014 Mazda 3 Grand Touring 6-speed with the factory Bose stereo system. Unfortunately, the door speakers and three dash speakers are blown. I've found information (not sure if true) stating the Bose stereo works off of a 2 ohm system while most other stereo systems and components run off of a 4 ohm system. Is this true?
IF it is, can I use after market speakers with the factory amp without burning it up? I'm sure using 4 ohm speakers on a 2 ohm amp will cause issues.
If I can use after market speakers, does anyone know what works best? (manufacturer/specific speakers/etc) I'd like to keep everything factory if possible, but am open to using after market components if I have no other choice.
Thank you in advance.
Endy.
Old Nov 6, 2025 | 02:07 PM
Bose is 2 ohm.. If your run an amp that is specification for 4 and 6 ohm speakers you should will be "muddled" and reduced and it is possible to damage both the amp and the 4 or 6 ohm speakers. I would be more concerned frying your BOSE amp.
There is way to do it but it requires lot's more money and a little stereo upgrading knowledge to do it correctly .
Contacting BOSE directly will confirm
Old Nov 6, 2025 | 02:12 PM
Enduros5's Avatar
Callisto,
Thanks for the response!
Yeah, I was afraid of that. I've seen several Youtube videos of people installing after market speakers with the stock amp. It seemed sus to me, so I check on the specific speakers shown in the videos and yep. They're all 4 ohms. Those amps will glow red hot I'm sure.
Looks like I have to find factory replacements. I've been searching but do you know of any site off hand that sells new drivers? Everything I've seen are for used ones.
Appreciate the knowledge!
Endy.
Old Nov 6, 2025 | 02:55 PM
Enduros5's Avatar
Ah! Good to know! Thanks man!
I think I'll try to find new drivers for now. Maybe in the future i can install a completely new system, but that's a fight for another day.
Thank you guys for all the information. You've been a big help!
Endy.
Old Nov 6, 2025 | 02:58 PM
Thank you for all the information. You've been a big help!
Endy.
You will damage the BOSE amp if you use other than 2ohm speakers. Contact a BOSE dealer to confirm this.
Bottom line its not worth taking the chance do it correctly and do it safe
Bose will state this :
Bose does not recommend using speakers with a different ohm rating than the original Bose speakers. Using speakers with a higher ohm rating than the original Bose speakers can lead to inefficient operation and potential damage to the amplifier. Bose speakers are designed to work with their specific ohm rating to ensure optimal performance and sound quality. If you are considering replacing your Bose speakers, it is important to use the correct ohm rating to maintain the integrity and functionality of your Bose amplifier.
Phone Monday - Friday
9 AM - 9 PM ET
Saturday
9 AM - 7 PM ET
1-800-278-1083
Old Nov 6, 2025 | 03:00 PM
Enduros5's Avatar
Good idea! I'll try that. I can't believe I didn't think of this.
Thanks again, Callisto!
Old Nov 6, 2025 | 03:11 PM
Enduros5 PM sent
Old Nov 6, 2025 | 03:18 PM
Enduros5's Avatar
Read and responded.
dandoescare
Dec 2, 2024 10:31 AM
Novanation
Dec 17, 2022 02:31 PM
Louisa23
Jun 15, 2021 09:45 AM
damrass
Sep 21, 2009 07:16 AM
2000smazda
Jan 22, 2007 09:08 PM
