Bomz CAI
Old Aug 22, 2006 | 04:57 AM
Grymlin's Avatar
Default Bomz CAI
Hi all im new here. I baught a BOMZ CAI from ebay about 2 months ago and havent had a problem with it at all. However i have noticed ever since i installed the CAI i get a delay when i press on the gas pedal..... Do any of you think that if i make the BOMZ into a short ram just taking out the second pipe and adding the filter to the first will it make a difference as far as the delay goes. I have a M 3s ...... 2.3
Old Aug 22, 2006 | 12:10 PM
the_gray_mazda6's Avatar
Default RE: Bomz CAI
just out of curiosity, where do you live? a short ram intake is typically good if you live in a hot environment such as Florida or places that are prone to flooding (have big puddles of water).
Old Aug 22, 2006 | 01:21 PM
Lupae3s's Avatar
ORIGINAL: Grymlin
after you installed you cai you should have noticed the quick instantaneous throttle response...
Old Aug 23, 2006 | 01:18 AM
Grymlin's Avatar
Well i do notice the throttle responce but after the delay. I mean once i press on the gas it delays at least one second then it hits.... I live in CA.....
Old Aug 23, 2006 | 02:09 PM
normally when you install an aftermarket part such as an intake, you are supposed to notice a better throttle response as well as less shift lag and a better low-end torque. maybe the intake cone is too small to suck in enough air to satisfy your vehicle. could you send us a link showing your exact intake, or do you have a picture of it? maybe the intake has too many curves in it which will make the performance aspect of it suffer tramatically...
Old Aug 23, 2006 | 02:16 PM
westimports's Avatar
The Mazda 3 shares the same MAF as the Protege 1.6L.
It has a long and well-documented history of hesitation problems when adding aftermarket intakes.
However, some intakes perform better than others. As a little 'plug' for myself, the Simota intakes I sell have not had this problem on the 3 or the 1.6L Protege. Speculation is that the diameter of the piping has something to do with it, although it's not really proven.
Old Aug 23, 2006 | 04:51 PM
Lupae3s's Avatar
if you are looking to completely get rid of that lag look into aem's cai...installed on my 2.3l and there is no lag or delay.
Old Aug 23, 2006 | 05:06 PM
ORIGINAL: Lupae3s
Mine's cheaper[8D]
$80.00 plus $15.00 shipping in the lower 48...here's a pic...
[IMG]local://upfiles/5518/0676C1698836459DAA112C6497E16575.jpg[/IMG]
Old Aug 23, 2006 | 06:43 PM
Grymlin's Avatar
well would you guys think if i shorten it to make it a short ram it should make a difference?
http://i17.ebayimg.com/01/i/07/cf/f2/72_1.JPG
Old Aug 23, 2006 | 08:31 PM
You could try it I suppose. Did you reset your ECU the first time you changed your intake?
