battery light on and off under moderate to hard acceleration
title descrbes it. some more info.
2006 mazda3 i
had a maf code, thought maybe thats what it was, replaced maf, no more code. (more power and smoother accel, but still flickering battery light.)
tested battery, passed. (basic load test, within 5 percent of rated cca)
checked wires, no obvious damage, corrosion, cleaned terminals anyway.
got a reman alt, put it on, still same story.
checked fusible link on alt to battery wire, was fine, but replaced it anyway.
new belt.
checked auto tensioner. other posts mentioned prone to failure because plastic. mine isnt plastic, maybe only plastic on 2.3?
checked forums, similar problems but in reverse to mine, so posting new.
possible that i got a bunk reman, but i also tried all the above with the original, a junkyard alt, and the reman, doeas the same exact thing with all three.
also stutters a bit, but only in second gear, and happens right as the battery light comes on.
so any ideas?
edit, forgot to mention, light does not ever come on when coasting, light throttle, or idle.
2006 mazda3 i
new belt.
so any ideas?
Alternator is controlled by the PCM.
Buy a cheap voltmeter that plugs into your cigarette lighter socket.
Engine running at idle should be 13.2 - 13.5v.
Keep a eye on it while driving.
I had a similar issue on a Nissan Sentra a number of years ago. It needed a new alternator. I would at least check that out (or have a shop do so) before it starts happening at lower RPMs and strands you somewhere.
In reference to your get it tested, I have done so already, with a induction load tester, pulls the full 90 amps on all three, the old one had one burned out diode, but was still working fine. Same with the other two. The issue is not with the alts, thus the post, and why it has me stumped.
MilleniaMan
Nov 28, 2013 11:02 AM
