Air Conditioning not cold?
Old Apr 11, 2011 | 02:30 AM
RyKerZ's Avatar
Default Air Conditioning not cold?
So we're approaching the summer months, and I've noticed that my air conditioning isn't cold.. like at all. It doesn't matter what fan setting is on, it either blows warm air lightly or heavily. Any ideas?
Old Apr 12, 2011 | 10:17 AM
Tracker's Avatar
couple of things to remember, under heavy or wot the a/c will not work. that aside you could just simply need to replace the cabin air filter (if you have one) or (hopefully not) there is something wrong with your a/c system like a leak, clog or something like that. I suggest having a garage do a a/c pressure check to see if things are within the correct range. just remember that it has to be atleast 65-70F to get a correct analysis.
Old Apr 12, 2011 | 03:52 PM
cornwellbs's Avatar
my gf has a oldsmobile bravada and her ac would only blow warm or hot air (and this was the middle of last summer) she got it checked at a gargae ans the some small little repay (or something likr that) they had to replace and, it wasnt am expensive part but with labor it was $800 cause they had to take the whoooole dash out
Old Apr 12, 2011 | 06:10 PM
Tracker's Avatar
corn, im 90% sure that it was her txv (thermal expansion valve) they replaced, its used to determine the temp of the refrigerant coming in and adjust accordingly. That particular type is located in the dash attached to one of the tubes, the one for the 3 is an h-block style which is located in the firewall and is much easier to gain access by removing the two refrigerant line running to it and then taking the bolt out. The only way that could go bad is if the system has been tampered with and is now contaminated and clogged.
Old Apr 19, 2011 | 01:28 AM
cornwellbs's Avatar
I don't remember what is was i just know it was like 10 hours of labor to get to it lol. Btw corn was my nickname in highschool lol
Old Apr 19, 2011 | 08:57 AM
Tracker's Avatar
haha, i just said corn instead of your full sn because im lazy :P
Old Apr 19, 2011 | 05:23 PM
cornwellbs's Avatar
lol its cool i actully prefer it lol
bacoli1
Aug 10, 2007 07:39 PM
Lanny Chambers
Jan 9, 2007 02:30 PM
swcejk2002
Jun 18, 2006 09:40 AM
the_gray_mazda6
Apr 3, 2006 12:47 AM
was98strat
Mar 30, 2006 09:46 PM
