Air Bags Indicator Light
Old Jan 2, 2008 | 11:16 AM
CARLOSPEED's Avatar
Default Air Bags Indicator Light
My Mazda 3 air bags indicator light just pop out and I had it check out with a computer
and didn't show nothing wrong. Did anybody had that problem before?
Old Jan 2, 2008 | 12:41 PM
sstlaure's Avatar
Default RE: Air Bags Indicator Light
Which light? The one in the instrument cluster or the one below the radio.
If it's the one below the radio, it's normal asthat is the weight sensing system in the passenger seat. The light will come on to show the passenger airbag has been disabled when there is a low weight detected in the pass seat. (Not sure what the threshold is).
Old Jan 2, 2008 | 12:44 PM
CARLOSPEED's Avatar
The one in the instrument panel.
Old Jan 2, 2008 | 02:10 PM
sstlaure's Avatar
If the airbag light is on in the cluster, then it should be tripping a code. I don't think you can read that with a regular OBDII diagnostic. Best to take it to the dealer and have it checked out.
Old Jan 2, 2008 | 03:23 PM
You could also try resetting it by disconnecting the battery for 10 mins or so, then reconnecting....?
Perhaps it was just a momentary glitch that caused it to come on in the first place?
Old Jan 2, 2008 | 03:38 PM
wineye's Avatar
ORIGINAL: sstlaure
Sstlaure, Could you please explain why the airbag light can not be read by the OBDII tool, thanks.
________
Zoloft settlement update
Old Jan 21, 2008 | 09:41 PM
A.phillyated's Avatar
My passanger airbag is off light ( the one that is below the radio) comes on all the time, regardless if someone is in the passenger seat or not. One time I had a very heavy bag in the passenger seat & the passenger airbag is off light stayed lit the entire trip. I thought the light is supposed to go off if there is 65lbs ( I think that is what the manual says)or more in the seat.
Old Jan 22, 2008 | 07:19 AM
sstlaure's Avatar
I've never tried reading airbag codes before,but my understanding of the OBDII port is that it pertains to engine mgmt codes (CEL), not any kind of restraint/safety device code. It's possible I could be wrong, as I said, I've never had to pull airbag codes before.
Old Jan 22, 2008 | 07:01 PM
I know that the air bags have their own control module mounted under the center console (Bosch) but I do not know if/how it interconnects/interacts with the EM ECU.
blackkeymaestro
Dec 15, 2006 07:18 PM
romanmojica
Sep 26, 2006 12:37 PM
Jobie
Suspension
Jan 12, 2006 01:21 AM
Supra Guy
Aug 23, 2005 03:11 PM
den_samsonov
May 12, 2005 08:44 PM
