2015 M3 Key Fob won't work after 1 hour
Old Oct 1, 2017 | 06:31 PM
paanM3's Avatar
Default 2015 M3 Key Fob won't work after 1 hour
NO-it's not the battery because I can start the car once inside!
So I set the proximity lock on door handle and went into work. Came out 8 hrs later & the Fob doesn't work on doors/trunk. Nothing, dead. Once i get the skeleton key to open door, the car will start & everything is fine. Fob works for doors/locks. This has happened the past 3 days. If I set the lock in my garage & try it up to +1 hour. later, all good. Any ideas??
Old Oct 1, 2017 | 07:56 PM
Once you hop in, I assume you just press the start button with your finger & it starts normally?
If you turn it off, hop out & try to lock it via the remote, what happens?
or
If you turn it off, hop out & try to lock it via the door handle button, what happens?
How often does this happen at work? Does it happen anywhere else over a long time period?
Old Oct 1, 2017 | 08:16 PM
paanM3's Avatar
for the 1st time yesterday, the car wouldn't start.
Once I hit the door unlock button on the door, it started
I can run the car, get out, & it locks fine.
I just checked @ 1 hour & it unlocks/locks
This happened the past 3 days at work.
Old Oct 1, 2017 | 10:13 PM
There might be something around your work interfering with the radio signal between the remote & the car ( car must read the remote before the handle button will unlock the car).
Keep us informed, & if it plays up at other locations.
Old Oct 2, 2017 | 06:57 AM
paanM3's Avatar
It happens anywhere/everywhere.
It happened to my wife when she went shopping(30 miles away)
It happens in my garage, as I set the lock before I went to bed & it wouldn't unlock this AM.
It happens at work.
It must be a time-delay sensor?? Once time elapses past a certain point, the Fob is shut-down. Scratching my head on this one....
Old Oct 3, 2017 | 07:28 AM
Isn't your car still under warranty?
Old Oct 3, 2017 | 09:30 AM
paanM3's Avatar
Nope- due to a Rebuilt Title.
Interesting news- I had the same issue yesterday, so I tried something different.
I parked my car in the garage & set the lock around 4. Before bed 10ish, I tried to open the door, nothing. So I just kept pressing the door handle button like 10 times, then the lights flashed & the door opened. Not sure why it takes 10 pushes instead of 1, but I don't have to use the Skeleton key now. I'd still like to know why it changed though...
Old Oct 6, 2017 | 04:10 PM
paanM3's Avatar
**** went South yesterday morning. Got in my car and the ignition button is flashing green, not good. Car would not start. Went inside and grabbed a spare fob, same deal. Now I'm panicking! Got out & started pressing the door handle button aggressively and the car went into a Beeping Mode. Unknown to me is that I initiated locking the door with my 1st key Fob inside. M3s do not like this & beeps persistently to warn you of this issue. Then out of the blue the horn chirps/headlights flash just like normal. So I hop inside & the car starts right up. Locks at work with the Fob & it's all good. I replaced both Fob batteries, just in case & now all is good.
Old Oct 20, 2017 | 01:17 PM
Jherrmann5's Avatar
I have just started having a similar issue on my 15 Mazda3. However, it seems to only happen in the mornings when I am leaving my house for work. The keyless entry won't work (using the door handle button), and I go to hit the unlock button on my keyfob, but nothing happens. I have to unlock the door with the key, and then the car starts right up when I'm in. When leaving work to head home in the afternoon, I have no issues using the keyless entry.
After replacing the key fob batteries, everything seems to be working fine now?
Old Oct 20, 2017 | 01:54 PM
paanM3's Avatar
Correct, BUT I did try to lock the door with a Fob inside(M3 do not like this!)by accident.
This might have reset the system because I heard a Beep
after hitting the button on the door about 25 times!
lsondubz
Jun 16, 2020 03:14 AM
SnowCanada
Jul 22, 2018 03:45 PM
TashT
Nov 14, 2011 11:26 AM
nentendo
Jun 2, 2008 11:51 AM
