2014 Mazda 3 ABS Light Won't Turn Off
Old Oct 2, 2024 | 01:24 PM
JackBauer007's Avatar
Default 2014 Mazda 3 ABS Light Won't Turn Off
I had the driver's side CV axle and sub frame replaced after it was taken into a field at around 55mph. So called mechanics returned car without bleeding brakes. I brought it back and they still didn't do it so I will not let them touch my car again. I bled the back brakes and pedal stiffness returned to normal. Ever since I got it back the ABS, TCS and TPMS lights are intermittently on. I checked the driver's front side and saw wheel speed sensor wire was zip tied on and taped together. I've now replaced that sensor twice, as well as disconnected the battery to clear codes and the same lights are always on now. I just took it to Advanced Auto to read the codes and it read U3000-49. One cause for this code can be that the abs light is on so I'm basically going in circles. Any help would be appreciated
90-B2200
Mar 6, 2023 05:45 AM
skyrider
Dec 29, 2022 05:47 AM
Newuser
Sep 23, 2021 07:23 AM
RyanL
Mar 29, 2016 10:28 PM
Coach-daddy
Jan 12, 2012 01:58 PM
