2008 Mazda 3 with a 2.0L
Old Mar 23, 2018 | 02:32 PM
Mazda3problem's Avatar
Default 2008 Mazda 3 with a 2.0L
My Mazda 3 runs good when on cold idle but once it warms up a bit it starts to surge or misfire when driving it just jerks back n forth a lot until it gets up to 4000 rpm and it runs fine until u slow down then it starts jerking and running like crap I've had it to a couple mechanics they don't know what's wrong no codes come up on the computer the check engine light is off all spark plugs seem to have spark they say the catalytic converter isn't plugged and changed the transmission fluid but nothing helps.. anyone who may know what wrong or got any ideas would be greatly appreciated
Old Mar 23, 2018 | 02:54 PM
shipo's Avatar
Step one, compression test; better still, a cylinder leak down test. Why? I suspect burned intake valves.
Old Mar 23, 2018 | 03:11 PM
I'm sorry if this sounds stupid but I'm not a mechanic.. but what's a cylinder leak down test?
Old Mar 23, 2018 | 07:44 PM
shipo's Avatar
A cylinder leak down test is kinda-sorta a super-duper compression test on steroids:When used on an engine, it can tell you whether you have a bad head gasket and/or cracked head/block (bubbles in the coolant), an exhaust valve leak (feed pressure leaking out the exhaust pipe, or intake valve leak (feed pressure leaking out the intake manifold.
Old Apr 1, 2018 | 10:38 AM
Brentjr10's Avatar
Default Vacuum leak
That could be a vacuum leak. Start by looking for anything obvious in the engine bay. Could be an actual vacuum hose undone, or could be a leaking hose due to dry-rotting. May be worth looking up a vacuum line diagram as well. Plus, this is a free place to start. Leak-down test is not.
jtmk
Aug 10, 2011 04:32 AM
jaimie08mazda3
Nov 9, 2009 03:30 PM
Herblenny
Jan 14, 2008 08:53 AM
sphinxter
Sep 10, 2007 09:43 PM
ray
Sep 7, 2007 02:31 PM
