2007 Mazda3 5door grounding problem?
Hello all, I have a problem with my 5 door Mazda3. When hooking up my ipod to the stereo through the AUX jack, it works fine. however, if I also plug it in with the power adapter, I get a hum that increases in pitch with the RPMs of the motor. this works when i plug the power adapter into the dash and into the console. i assume this has to do with a grounding problem?
anyone else have this problem? i used the power adapter without incident in my previous car.
thanks
thanks
This is a common problem, and is most likely because Mazda didn't put the effort into it to have it grounded properly. First off make sure you complain to mazda (not necessarily your dealer, but corporate). If enough people complain then they may issue a TSB. Second go buy a 3.5mm ground loop isolator. You can also get them with RCA connectors, except then you're going to have to use adapters so you might as well just start with 3.5mm ones. You can get them from www.Crutchfield.com, and www.discountcarstereo.com for about $15.
kali_mx3
Jul 18, 2008 04:28 AM
