04 Hatch stalling/CELS with Injen CAI
Old Jul 7, 2010 | 09:51 PM
chrisa741's Avatar
Default 04 Hatch stalling/CELS with Injen CAI
60K on engine, noticed it's been REALLY humid out the past couple of days so now the car is stalling and the CEL is on. I reset the battery, checked all connections, same thing. Had the same prob a couple years ago so i took it off and put back the stock airbox on (boo!) The Injen has been back on for the past 2 months with on and off CELS. Anybody else having these issues? Thx.
Old Jul 8, 2010 | 06:34 PM
Tracker's Avatar
worst case is that the pins for the MAF have been pulled out, the stock harness to is too short for the MAF and its common to hear about those who have had to extend the wires and give it some slack. Other than that it could be that your filter needs to be changed, the MAF is about to crap out, OR its just a gamble thing and teh pcm just decides that it doesnt like the extra air its getting. In short the car is a pain when doing light mods
Old Aug 2, 2010 | 09:45 PM
rob23's Avatar
deffenetly somthing with the MAF sensor, double check it.
Old Aug 3, 2010 | 01:26 PM
Aubrey's Avatar
Someone should make a CAI that connects at the hose and stock filter box so you don't have to mess with the MAF sensor.
Old Aug 4, 2010 | 09:51 AM
rob23's Avatar
they do its a K&N Drop in Filter. but it doesn't do much at all.
Old Aug 4, 2010 | 01:16 PM
shipo's Avatar
Sure it does, no power/economy gain and a decrease in filtering capability.
Old Aug 4, 2010 | 07:16 PM
Tracker's Avatar
Actually we have a flow bench to test aftermarket intakes and filters, aem, k&n, and some others all show an increase of flow over oem, and on the dyno it shows as well
Old Aug 5, 2010 | 08:45 AM
shipo's Avatar
Sorry, not buying. In this case I believe the reference was to a "drop-in" K&N, a filter with demonstrably poor filtering capabilities with absolutely zero improvement in any performance metric.
Old Aug 5, 2010 | 04:17 PM
apbbnbanb_07's Avatar
Man, everybody wants to argue with you Tracker.
Old Aug 5, 2010 | 09:08 PM
Tracker's Avatar
So if i showed you a flow chart stock vs aftermarket as well as a dyno showing an increase you still wouldnt buy it???
