Tie rod arm
Old Apr 8, 2025 | 03:53 PM
kennyredline's Avatar
Default Tie rod arm
My garage won’t do an alignment on my 2014 Mazda two because they are telling me the driver side inner tie rod arm has play in it. Only 30,000 km on the vehicle, is it common for these parts to wear out that soon mileage wise?
Old Apr 9, 2025 | 03:28 PM
No its not common and likely caused from the owner. Don't take offence because .....the alignment shop should have given you a better indication as to the cause.
Old Apr 10, 2025 | 12:21 PM
M Two's Avatar
TWO's suspension was doing quite well at 45K Miles. Then my husband suffered some medical problem that required many trips to the medical center in Washington, DC - mainly on residential roads. Apparently, there is no maintenance budget. Mine was just one tie rod end kaput. So, no. Low mileage 2s should not have problems. However it depends on where you drive, road conditions, and how you drive.
Old Apr 16, 2025 | 11:42 PM
Charlescrown's Avatar
Have someone look at it. I have seen them come loose. If it's worn their cheap and easy to replace.
zsteve
Dec 22, 2023 05:04 AM
lusinia
Jul 20, 2016 07:43 AM
mazpro00
Jan 29, 2014 01:08 PM
lmbarns
Jan 31, 2012 08:51 AM
MAZDAMANIA
Jan 14, 2007 12:58 AM
