Mazda 2 2015 SkyActiv-D Sedimentor
Old Aug 12, 2023 | 02:09 PM
walweb's Avatar
Exclamation Mazda 2 2015 SkyActiv-D Sedimentor
I have a flashing wrench which indicates Sedimentor needs to be drained after 20kms.
Does anyone knows where it's located? I can't seem to find it.
Old Aug 13, 2023 | 03:08 AM
Assuming it's the same as a CX-3 diesel, the fuel filter should be under the car, just in front of the fuel tank.
Old Aug 13, 2023 | 09:07 AM
Old Aug 16, 2023 | 05:33 PM
walweb's Avatar
thank you, I found it but when I started draining it, appears only fuel coming out.
Old Aug 16, 2023 | 06:43 PM
Mazdaon's Avatar
So? water is denser than fuel and it will accumulate at the bottom of filter if it's none there the fuel you pump it's very good.
Now you need to reset the maintenance light with a good OBD scanner.
escott81
Jun 24, 2023 02:36 AM
Kathleen Reynolds
Mar 6, 2023 05:33 AM
ABC Garage
Jan 24, 2020 10:24 AM
ikeym
Apr 5, 2015 10:53 AM
maxinc
Aug 25, 2014 09:17 AM
