Mazda 2 2011 engine mounts
Old Mar 23, 2022 | 10:40 AM
the_bart123's Avatar
Default Mazda 2 2011 engine mounts
Hi there
I still fight with my Mazda 2 2011 engine mounts - so I already replaced bottom one and now I fight with upper ones which I do not know where they are.
Here is photo of "something mine"
And when I search online (by my reg plates) it shows me different results - like:
https://www.ebay.co.uk/itm/183435114336
Which looks like differently
Then I see this one:
https://www.ebay.co.uk/itm/201388032222
Is there third engine mount in Mazda 2?
Thank you for helping me
Old Mar 24, 2022 | 05:59 AM
RHS mount'
Lower/rear mount
Gearbox / transmission mount.
Old Jul 2, 2023 | 06:53 PM
BLAlley's Avatar
The photo shows the upper right motor mount, and this is the one that will most likely fail since it's a top-mount cantilever design. The mount comprises the aluminum arm with the three bolts to the engine and the steel "can" that mounts to the inner fender well. If you have an automatic transmission there should be a damper that looks like a rubber cylinder adjacent to the single bolt on the aluminum portion.
When this mount fails the engine will seem to run rough and make more noise.
Try Parts Geek.
Normal under-mount motor mounts tend not to fail on four-cylinder engines because they don't generate enough torque to stress the mounts.
HuwG
May 4, 2024 09:06 AM
Trailmaster
Aug 28, 2020 04:42 AM
mazdademio
Jan 24, 2015 05:09 AM
Camdenbullitt52
May 3, 2014 09:26 PM
MarkMazda
Aug 13, 2011 02:58 PM
