MAP Sensor location and removal - Mazda 2 (DY) 1.5L ZY-VE
Old May 6, 2024 | 04:21 AM
crescent6405's Avatar
Default MAP Sensor location and removal - Mazda 2 (DY) 1.5L ZY-VE
Where is the MAP sensor located on the ZY-VE engine, and how is it removed?
I have found two sensors which I think may be the MAP sensor (photos attached)
This is under the left side of the air box (facing the windscreen(
This is on the right side of the intake manifold
but I am not sure. Also, one of them appears to be harder to remove than MAP sensors on other cars I've seen.
Any help much obliged.
Old Dec 13, 2024 | 06:45 AM
WavinSouth7's Avatar
Default MAP sensor
Hey, I have the same engine and I need to upgrade the OEM map sensor to one that could register positive boost since I turbocharged my engine. Any luck finding the MAP sensor on this engine? Thanks
Old Dec 13, 2024 | 07:02 AM
Hi. It is not visible to me anywhere looking into the engine bay
Based on that, I believe it is likely fitted inside the intake manifold itself. While I have not removed the manifold myself, I am almost certain that's where it is. Hope that helps.
Old Dec 13, 2024 | 07:04 AM
Default MAP sensor
Wow! Well thanks for your quick response. What were those other 2 sensors you sent pictures of by the way?
Old Dec 13, 2024 | 07:25 AM
Ah, I was thinking of a different car. The MAP sensor on the ZY-VE engine is shown in the first photo, under the left-hand side of the air filter housing. You will need to remove the air filter housing to access it. Not sure what it is in the second photo.
Old Dec 13, 2024 | 07:28 AM
Default MAP Sensor
No worries at all man. Thanks so much! You saved me a lot of headache.
Mjro
Jun 5, 2023 06:49 AM
MasterAbacus
Oct 31, 2020 03:40 PM
Keyl200
Mar 31, 2020 03:47 PM
Mazdan6
May 8, 2017 09:59 AM
will1407
Oct 17, 2015 05:08 AM
