How to enter radio code - New Battery fitted
Old Oct 29, 2025 | 01:05 PM
Milko's Avatar
Default How to enter radio code - New Battery fitted
My 2009 Mazda 2 failed to start this morning due to a flat battery.
After fitting a new battery the radio now won't work and just shows "CODE".
Any idea where I could find out what the code is, also how do i enter it.
Thanks for any help offered.
Old Oct 29, 2025 | 01:28 PM
This is for DIY not practiced in a professional service shop.
Did you happen to touch the battery terminal more then one time on the last cable attaching to the battery. If so disconnect the battery again ground cable, then the positive cable. IN THAT EXACT ORDER
The after about 5 minutes reconnect the positive cable and then last the ground cable IN THAT EXACT ORDER and do not touch the batter terminal more then one time during the reconnection of either cable. Even lightly touching it can send a voltage through the vehcle and to the ECU and BCM.
After this see if everything now works correctly?
Old Oct 29, 2025 | 01:53 PM
Milko's Avatar
Thank you for the information, I will try it in the morning.
Old Oct 30, 2025 | 09:54 AM
Originally Posted by astroboym
i did a search on your problem and came up with this.
to find your mazda 2 radio code, check the owner's manual or look for a sticker in the glove box. if you cannot find the code there, a mazda dealer can provide it using your vin and proof of ownership. avoid entering incorrect codes, as this can permanently lock the radio.
good luck!
hello conrad 16.5
Old Nov 1, 2025 | 08:44 AM
Originally Posted by **AstroboyM
In most cases the circuit does not care where the interruption takes place. It's either a completed circuit or it is not.
hello conrad16.5 who do you think your fooling here we already know!
Super troller and my personal forum stalker ^^ **I.P. and member tracking don't lie
Last edited by grim_reaper; Nov 3, 2025 at 12:02 AM. Reason: Moderated by Super Moderator
Seve
Mar 4, 2021 04:23 PM
rbinuk
Nov 17, 2020 12:50 PM
Borgy
Apr 6, 2020 01:23 PM
Louise Grima
Dec 19, 2019 01:00 PM
Jackie
Dec 13, 2012 10:41 AM
