Brake drum squealing
Old Jan 13, 2026 | 06:05 AM
JL1996's Avatar
Default Brake drum squealing
Hi all, I am new here. My girlfriend has a 2019 Mazda2 (AUS) and it has a bad brake squeak from the rear. I have already removed the drums and cleaned out all of the shoe dust but it has returned less than 2 weeks later. Is there a more permanent fix? I know it’s an enclosed system so it will build up but 2 weeks is crazy. Cheers
Old Jan 13, 2026 | 09:06 AM
Old Jan 13, 2026 | 04:33 PM
Charlescrown's Avatar
A light sand by hand of the drum surface and the shoe lining material
may help.
Old Jan 13, 2026 | 06:18 PM
Noises like the ones being described means there is a negative underling reason and should be looked at carefully before simply canceling out the noise with a quick fix remedy.. just saying...they are brakes!
Old Jan 14, 2026 | 01:54 AM
Robbie4T's Avatar
Hi JL1996,
As Callisto has said. This is the brake system, which is a critical item. Is the slave cylinder leaking ? Or seized, Or sticking? Detailed inspection is required. replacing the brake shoes would rule out a problem with these, which would seem the easiest job. Contamination of these from brake fluid leaking from a slave cylinder maybe could be the reason. Or maybe just they are worn out.
Also, some car disc brake pads are designed to squeal when they are worn down to near there wear limit. It may be an idea to check those as well.
For A Mazda 2 DJ the wear limits. New disc brake pads that I've seen on cars normally have somewhere near 10mm thickness of material.
Old Jan 14, 2026 | 03:44 AM
From my experience with the Mazda 2's, if they aren't adjusted perfectly they can squeak. Make sure the cable is wound back before adjusting the shoes.
Its hard to explain.
Old Jan 14, 2026 | 08:27 AM
There are NO brake pads designed to "squeal" but what some may be refereeing to is the wear tab that will sound like metal to metal which is meant to gain atttention to the driver to have the brakes checked and the pads serviced.
Ian David Harwin
Nov 27, 2019 10:30 AM
liliafan
Sep 18, 2009 11:58 AM
Burkhart
Apr 20, 2007 04:56 PM
ozmazda1993
Jan 18, 2006 12:10 AM
mainman2c
Jul 21, 2005 02:19 AM
