Adding Electric Turbocharger to Mazda Demio GT Sposrt Nav+ 2019
Hi everyone,
In about 2 years I plan to spend about 8k on mods and I would like to start adding some power to my car.
Like in the topic, I am thinking of adding an Electric Turbocharger single or in twin config which should add 20$ - 35% power.
Forget about all other things I will need to add for now... Is it even possible to use that Turbo with 1.5 L SkyActiv-G F-P5 I4 Engine and 5-speed SkyActiv-MTmanual transmission?
I am asking because I haven't seen anyone to try this... in fact, I haven't seen any Mazda 2 with Turbo...
If not then why not? Will engine not be able to handle the strain?
Thank you,
Hunter
Thank you,
Hunter
A few points:
- Most "electric" turbochargers are absolute crap meant to fleece money from the unsuspecting.
- A high end electric turbocharger driven from a big freakin' capacitor to give a few seconds of boost are fairly expensive, and if you're climbing a long grade, you'll be out of boost in relatively short order.
- SkyActiv-G engines make very poor candidates for forced induction simply because their compression ratios are too high to accommodate the boost.
Thanks for the answer.
I agree many are just crap but I got one that's good, tested, and makes 5 PSI (https://torqamp.com/) £2.5k which is cheaper than a normal one, and it is much easier to install cuz you don't need to change the exhaust.
It does offer a short burst, I guess for about 1 min depending on how big battery is, but you control it with a press of a button so you only use it when you need it, 6 bursts is good enough to have some fun I guess.
That's what I thought, but then again, it should give that 20% more torque. I'll have to spend some time and calculate it myself I guess.
Without running the numbers, my gut tells me even a 20% bump in torque is dubious. Why? As I mentioned before, you have a SkyActiv-G engine, which I believe in the U.K. market sports a 14:1 compression ratio. Given most of the U.K. is very near sea level, adding a 20% denser intake charge, unless it was hyper-cooled through ice water or something, will probably lead to significant, and potentially terminal, detonation.
A few points:
(Legend says someone pointed AC at the engine to cool it down
