[ 2012 Mazda Mazda2 ] OEM radio pinout / schematic / wiring diagram requested
Hello.
I am searching for the pinout / schematic / wiring diagram for the OEM stock radio for the 2012 Mazda Mazda2 vehicle.
Radio model number: 14797439
OEM radio from the dealership.
I have spoken with both the dealership's parts department as well as their OEM vendor; neither have the schematics and resort to 'replacing damaged components' only as opposed to repairing components and as such do not carry the unnecessary diagrams.
If anyone has pinouts of the radio: Please share a URL, hand drawn image, explanation of each pin / function or other.
Thank you, very much!
Hello.
Image of the radio's part and model number:
![[ 2012 Mazda Mazda2 ] OEM radio pinout / schematic / wiring diagram requested-1000000890.jpg](https://www.mazdaforum.com/forum/attachments/mazda2-53/8990d1707004144t-%5B-2012-mazda-mazda2-%5D-oem-radio-pinout-schematic-wiring-diagram-requested-1000000890.jpg)
Image of the pin connector boxes with the radio panel removed:
![[ 2012 Mazda Mazda2 ] OEM radio pinout / schematic / wiring diagram requested-1000000938.jpg](https://www.mazdaforum.com/forum/attachments/mazda2-53/8991d1707004144t-%5B-2012-mazda-mazda2-%5D-oem-radio-pinout-schematic-wiring-diagram-requested-1000000938.jpg)
Image of the gray connector box:
![[ 2012 Mazda Mazda2 ] OEM radio pinout / schematic / wiring diagram requested-1000000937.jpg](https://www.mazdaforum.com/forum/attachments/mazda2-53/8992d1707004144t-%5B-2012-mazda-mazda2-%5D-oem-radio-pinout-schematic-wiring-diagram-requested-1000000937.jpg)
Image of the center connector box:
![[ 2012 Mazda Mazda2 ] OEM radio pinout / schematic / wiring diagram requested-1000000936.jpg](https://www.mazdaforum.com/forum/attachments/mazda2-53/8993d1707004144t-%5B-2012-mazda-mazda2-%5D-oem-radio-pinout-schematic-wiring-diagram-requested-1000000936.jpg)
Image of the right connector box:
![[ 2012 Mazda Mazda2 ] OEM radio pinout / schematic / wiring diagram requested-1000000935.jpg](https://www.mazdaforum.com/forum/attachments/mazda2-53/8994d1707004144t-%5B-2012-mazda-mazda2-%5D-oem-radio-pinout-schematic-wiring-diagram-requested-1000000935.jpg)
Thank you, in advance!
Hello.
This may help
Extract from Mazda2 Manual
2010 Mazda North American Operations USA
2014_01_29
Pg193 of 3,782
Audio Unit Wiring Harness-Side Connector
![[ 2012 Mazda Mazda2 ] OEM radio pinout / schematic / wiring diagram requested-radio-pin-out-connector-1.png](https://www.mazdaforum.com/forum/attachments/mazda2-53/9000d1708681897t-%5B-2012-mazda-mazda2-%5D-oem-radio-pinout-schematic-wiring-diagram-requested-radio-pin-out-connector-1.png)
Also Extract of Detail from 000 WIRING DIAGRAM.pdf - 109Pgs
AUDIO UNIT
Pg71 - 0920-2a
Term = Wire Colour, Purpose
1R = GY/R(l), from 7.5A Fuse
1B = L/R(l), from 15A Fuse
1I = G/R(I), to Instrument Cluster
1W = B(I), to G05 (Chasis Ground)
Pg72 - 0920-2b
1C = W(I) & 1A = R(I), to Front Door Speaker LH
1D = L(I) & 1F = Y(I), to Front Door Speaker RH
Pg73 - 0920-2c
1U = P(I) & 1S = V(1), to Rear Door Speaker LH
1X = B/L(I) & 1V = W/L(1), to Rear Door Speaker RH
1P = G/W(I), to Clock Spring Terminal 16
1N = R/B(I), to Clock Spring Terminal 14
Pg74 - 0920-2d
2M = G(I) to Auxiliary Jack
2L = B(I) to Auxiliary Jack
2I = W(I) to Auxiliary Jack
2K = R(I) to Auxiliary Jack
2A = P/B(I) to Auxiliary Jack
Rob
2014_01_29
Pg193 of 3,782
AUDIO UNIT
Pg71 - 0920-2a
Pg72 - 0920-2b
Pg73 - 0920-2c
Pg74 - 0920-2d
Rob
This may help
2014_01_29
Pg193 of 3,782
Attachment 9000
AUDIO UNIT
Pg71 - 0920-2a
Pg72 - 0920-2b
Pg73 - 0920-2c
Pg74 - 0920-2d
Rob
2014_01_29
Pg193 of 3,782
Attachment 9000
AUDIO UNIT
Pg71 - 0920-2a
Pg72 - 0920-2b
Pg73 - 0920-2c
Pg74 - 0920-2d
Rob
Thank you! I read everything you shared. It is very helpful. I only need to address a no-spark condition now before I can install my (Chinese) Android headunit.
