Transmission problem
I need some help mith a transmission problem.
The overdrive light is flashing and the transmission passes from the 1st to the 3th gear skipping the second gear.
A mazda repair shop puts the scanner on with no result.
Any thoughts?
Any thoughts?
Same result with either OD on or off.
It looks it's more likely that the transmission shift at a much higher RPM almost 3500-4000 before engaging the next gear.
If I accelerate very hard, it will miss the gear and the engine will rev up.
Any idea?
Any idea?
