Starting proble.
My 2001 Tribute 3.0 V6 has an intermittent starting problem. This only happens when the outside temp is really cold or cold a raining. The car will crank but not start. It cranks strong and there are no strange sounds. The PAT system is working properly. The fuel pump is fairly new and the fuel filter is about a year old.
It usually will eventually start and will continue to start instantly the rest of the day.
Does anyone have an idea what could be causing this annoying problem?
As stated, this problem only occurs when it's cold and rainy, first start up. If any of the above was bad, this problem would happen all the time. Once the engine heats up and drys, the problem goes away.
Hello.
I have a cx5 diesel from 2014 and a problem with starting the car on a cold engine (longer time), this happens after a large service (oil, filters, fuel filter, filling the fuel), before the service was ok. Thinking there is a problem with the fuel filter I exchanged him alone again and it was fine for three days the car started normally. After three days, the car turns on a cold engine for a long time. I was in diagnostics in Mazda but did not find anything because he started to normally again, after which I noticed that he only has a problem when it's raining and sometimes as the temperature drops. after a few days of observation, it fires worse as it rains, there is no rain it is ok.
Maybe somebody help me with this problem.
What i'd do is check to see if there is spark on a cold day 1st at least , then pull/clean all those main connectors , one has to figure out what is lacking , spark or fuel and make sure the battery voltage is not dropping too much at crank . .
Hello.
In the proper thread area might help .
