Sea belt buckle
Old Jul 18, 2010 | 05:53 PM
iHeartMazda's Avatar
Default Sea belt buckle
My driver seat seatbelt buckle wont buckle anymore. I dont know what's wrong with but it wont buckle. Does anyone know how much it will cost me to get that replaced? I really dont want to go to the dealership because they will charge me an arm and a leg.
Can I find the buckle at like AutoZone or any Auto shop?
Thanks in advance
ETA: Shouldn't the warranty cover that? After all, I didn't do anything to it. It just wont buckle.
Old Jul 27, 2010 | 06:52 AM
oriette's Avatar
Default seat belt buckle
The costs depend on whether your buckle system has a pretensioner or not. If you have a buckle pretensioner the complete replacement will probably cost you up to 1000 USD (worst case). Half price without.
As a former buckle/buckle system developer I would suggest to proof the functionality of the buckle first. Does any part of the buckle move? Maybe parts of the buckle adhere to clammy contaminants. If parts are cleaving try to funnel clear water into the buckle (through the slot of the tongue) until it is working again (catch water at the end of the buckle with a bucket).
If this isn`t leading to success try to look inside the buckle. Maybe a steel feather (ejector spring) was falling out of her bearing. Try to mount her back to her position (very difficult if you don`t know the system). Maybe you bring home the bacon...
Otherwise:
If the above written method doesn`t also lead to success, open the buckle covers with a srew driver (maybe the covers are joined with 2 srews or by clips). Normalwise you have to take a torque screw driver if there are screws. If there are clips (snap-fits) you have to open the caps with force (the joining of the caps will be destroyed). There is no other way to remove parts (you cannot remove the buckle). After removing the covers open the buckle and have a look what part is failing. Regularly you will find a dislocation of parts (mostly feathers). Otherwise there will be contaminants in the buckle - remove them if you see any. (If parts are broken you have to replace the buckle professionally.) You can try to latch and delatch the buckle without any latch. Latch the buckle while compressing the ejector and delatch by pressing the pressbutton.
After repairing the system trim the covers with a gripper and stick the trimmed covers together with superglue (put the superglue only on the connection edges).
This is the cheapest method to repair it....
Kind regards
Oriette (Switzerland)
Old Aug 2, 2010 | 07:59 PM
Thanks!
But I got that fixed. It was fixed for FREE. Turned out it was still covered under warranty.
Thanks again, though.
virgin1
Nov 15, 2009 06:05 AM
MikeMzda3
Jan 5, 2009 10:19 AM
2000grnS
Feb 17, 2008 12:01 AM
Dino1956
Jun 5, 2007 09:08 PM
rooster2
Apr 23, 2007 06:49 PM
