Red Warning Light
Old Feb 15, 2011 | 11:43 AM
turboturney's Avatar
Question Red Warning Light
Hi All, I own a 2002 Mazda Tribute V6 and the red warning light on the dashboard for coolant empty is on but the expansion bottle is full. any Idea`s Please
Old Feb 15, 2011 | 12:02 PM
lnwlf's Avatar
check coolant in radiator, or bad sensor
Old Feb 16, 2011 | 12:00 PM
djs2571's Avatar
as lnwlf said - make sure there's coolant in the radiator, not just the overflow.
It's possible there's a head gasket leak or similar that is blowing air into the radiator - and therefore filling the overflow tank... but at the same time, not pulling fluid back into the radiator when it cools off - a cracked radiator (bad seal) could do this before it shows up as a leak too.
Otherwise, bad sensor.
Old Feb 21, 2011 | 10:04 AM
TomV's Avatar
How full is full? If just to the Full line, then add more and check the light. If the light stays on then the sensor (or wiring) is bad.
If the fluid level drops in the future then you have a leak somewhere.
B-T-S
Apr 27, 2015 01:30 PM
Mel
Jan 24, 2009 06:04 PM
hakunanakata
Nov 11, 2008 11:35 PM
hakunanakata
Nov 11, 2008 11:25 PM
