Red Warning Light
Hi All, I own a 2002 Mazda Tribute V6 and the red warning light on the dashboard for coolant empty is on but the expansion bottle is full. any Idea`s Please
check coolant in radiator, or bad sensor
as lnwlf said - make sure there's coolant in the radiator, not just the overflow.
It's possible there's a head gasket leak or similar that is blowing air into the radiator - and therefore filling the overflow tank... but at the same time, not pulling fluid back into the radiator when it cools off - a cracked radiator (bad seal) could do this before it shows up as a leak too. Otherwise, bad sensor. |
Originally Posted by turboturney
(Post 116266)
If the fluid level drops in the future then you have a leak somewhere. |
