Question about O2 sensors.
Old Jan 30, 2019 | 05:22 PM
James Jeffreys's Avatar
Default Question about O2 sensors.
I have a 2001 Mazda Tribute LX V6 3.0L.
Is bank 1 sensor 2 considered upstream or downstream or are they interchangeable on this model?
I'm trying to order the correct part.
Thanks in advance.
Old Jan 30, 2019 | 08:24 PM
simonsi's Avatar
AFAIK (and on my 2001 V6), there are only upstream (ie pre-catalyst), O2 sensors fitted, so the O2 are used to trim the fuel injection but cannot tell the car how well (or not) the cats are working...the sensors are in the top of the manifolds where the 3 header pipes join, above the cat bulge in the downpipes.
Old Jan 31, 2019 | 05:11 PM
So are they all upstream and is it just 3?
Old Jan 31, 2019 | 05:17 PM
simonsi's Avatar
Just 2, one in each exhaust manifold. There are 3 cat converters but only the 2 O2 sensors
Old Feb 1, 2019 | 09:42 AM
I appreciate it. Ty.
Old Feb 3, 2019 | 04:34 AM
There should be 2 x A/F( air / fuel ) sensors ( pre cat ) & 2 x 02 (oxygen ) sensors (post cat ) in the exhaust of the V6. ------ Cat = catalytic convertor.
Bank 1 sensor 1 is the front bank A/F sensor
Bank 1 sensor 2 is the front bank post-cat O2 sensor
Bank 2 sensor 1 is the rear bank bank A/F sensor
Bank 2 sensor 2 is the rear bank post cat O2 sensor
Old Feb 3, 2019 | 05:39 PM
Ahh. Okay. Which is considered upstream and downstream and tyvm for the info.
Old Feb 3, 2019 | 05:52 PM
simonsi's Avatar
If you look under the front of the engine where the front manifold pipe goes horizontally towards the right wherl, if you have the after-cat sensors one will be there.
Our 2001 and 2002 V6’s dont have them but if yours does the “sensor 2” or downstream sensor will be there. Those between the cylinders and cat are upstream, those after the cat are downstream, think fishing from a bridge (the cat), upstream and downstream would be as you refer to the direction from the bridge.
Old Feb 4, 2019 | 06:41 PM
Thank you for the info. That helped clear it all up. Also thanks to everyone who responded and helped me with the issue. I really appreciate it. 😊
danijel
Feb 12, 2012 10:01 PM
mzdaspd304
Feb 16, 2007 04:29 PM
Andy323
Nov 26, 2006 09:15 PM
dario pita
Jun 21, 2006 10:36 PM
danijel
Jun 22, 2005 09:10 PM
