PLugs and Wires
Old Aug 18, 2007 | 02:17 PM
tribby05's Avatar
Default PLugs and Wires
Want to change both, can someone post details on changing plugs and wires, as well as any suggestions on performance parts eg. NGK plugs etc. there are many to choose from like platinum, 4 electrode, etc..
thanks
05' tribute 3.0litre
Old Aug 19, 2007 | 09:39 AM
jimmythekid1's Avatar
Default RE: PLugs and Wires
well you don't have any wires to worry about you have 6 coils one for each plug. I would just use the factory motorcraft plugs they will work the best in your engine. You will not achive any performance gain from replacing the plugs though.
The process it quite easy remove the plenum there are only a few vacuum lines a egr stuff you have to worry about its preety strait foward. You can replace the plenum gaskets if you want I recommend it but your might gett away with replacing them.
all in all its a easy job good luck
Old Aug 19, 2007 | 12:36 PM
tribby05's Avatar
thanks
brijamgel
Feb 6, 2021 01:35 PM
BobDayton
Apr 19, 2015 01:42 PM
windbk
Feb 4, 2013 05:11 PM
hetrick01
May 20, 2007 10:48 PM
Lupae3s
Sep 20, 2005 06:08 PM
