P0456 Code
Old Mar 18, 2008 | 01:10 AM
jdandboyz's Avatar
Default P0456 Code
I have a 03 Tribute 4WD, 4cyl,5 sp. There seems to be a very slight hesitation around 25-35 MPH, the Check Engine light came on, and the following code was retrieved:
P0456 Evaporated emissions systems leak detected (very small leak) ON 2 Evaporative.
I was toldthat this is usually a loose or faulty gas cap issue. I replaced the cap with a new one and reset the system,the slight hesitation continued, and After about a week the light came back on, Ichecked it again and found only the same code as before.
Prior tothis I had a sticky throttle body, I sprayed it with carb cleaner to remove all the gummy deposits, I also changed the air filter and spark plugs, and wires. Have not replaced the fuel filter.
Any ideas??
Baston-Rob
Dec 25, 2011 04:48 PM
Bobbygian
Sep 30, 2010 09:07 AM
