Manuel Trans. Shift Cable
Old Sep 9, 2011 | 11:49 PM
Driveway Al's Avatar
Default Manuel Trans. Shift Cable
I thought the clutch was going but now I thinking my shift problem may be due to a the shifter cable link where it connects to the lever on the transmission. There seems to be some play at the bushing in the link. I had my friend shift while i watched it move and the metal/rubber bushing that connects it to the rod on the lever seems to have play in it. I am having hard time shifting into 2nd and reverse. Both of these push the lever in the same direction. Has anyone else out there have same problem with the linkage. Does a new shift cable come with the bushing on the end. Car is 2001 Mazda Tribute 5spd. Thanks.
DrivewayAl
Old Dec 23, 2011 | 03:02 PM
Dieseltank's Avatar
Hi,
Litytle late in answering. My 2011 Tribute also has thisfree play on the gear shift cables. In a previous post on this site you find the solution: the rubber bushing on the gearbox cable pivots are worn. Mazda sells only the complete cable set for a lot of money. I solved only it temporary it by winding tape around the pivots and mount the origional rubber bushing again. Meanwhile the problem occurred again; probably the tape is gone.
Better replace the rubber with a plastic bushing; this will be my next job on the vehicle.
Bert
Shelby563
Oct 28, 2014 10:34 PM
mothmazdaman
Jun 30, 2014 09:49 PM
Will Thomas
Jul 5, 2010 08:06 AM
elcordovez
Jun 13, 2010 12:52 AM
cuteassad
Feb 10, 2010 08:53 AM
