Installing a Sub
Old May 11, 2014 | 04:47 PM
paintballer99's Avatar
Default Installing a Sub
Hello all,
Has anyone installed an aftermarket sub in their tributes? I installed a sub in my other car, and now im considering doing the same for my tribute but im wondering if anyone has done it already and how difficult was it?
Thanks!
Old May 11, 2014 | 07:05 PM
This is for general extra amp installation: You need really thick power wire if you go more than 10 feet. If you go with an extra battery you will need an isolator.
You must not only ground your amp, but add another ground wire to the body near the front of your main battery from the negative terminal of the battery. I suggest also adding a ground to engine from negative terminal of battery.
Sorry, if you know this already, but alot of people don't. I knew of a guy that didn't add an extra ground wire to battery and fried his stock ground wire!
Old May 11, 2014 | 08:57 PM
your setup looks good and really clean! where did you put your amp? is that just on the floor behind the front seat? I just have one 15" sub that im going to use and just mount it in a ported box in the back but im debating if i should just put the amp right next to it.
Also you put your power line through the firewall correct? My car is a few states away right now so i cant really look at it right now!
Old May 12, 2014 | 07:57 AM
Yes power wire thru firewall. Rubber grommet or silicone needed there.
I put power amp behind front seat as when it was at the back of car, i lost bass response because power wire was too long. It is 4 gauage. Anything longer than 10-12 feet, you need thicker than 4 gauge.
I actually installed a cooling fan as well as a top to hide amp. No one ever sits in back. Cooling fan has an extra switch so i can turn it off in winter. When switch is on, it actually turns on and off automatically with stereo. 12 volt cooling fans easy to buy at surplus places, hardware stores.
Top is just carpeted plywood---top is held up in place by attached cooling fan and wood at other end. In summer you need cooling fan because in car temps can be very high.
bajanbum
May 10, 2010 12:29 PM
MAZDA MAN
Sep 16, 2005 03:27 PM
Metric
Aug 26, 2005 04:09 AM
MAZDA MAN
Aug 15, 2005 05:57 PM
MAZDA MAN
Jul 11, 2005 04:28 PM
