engine diagnostic test: error codes #171 & #174
Old Feb 24, 2007 | 05:19 PM
believe1470's Avatar
Default engine diagnostic test: error codes #171 & #174
hey all. I've got a '01 Mazda Tribute ES-V6 and I've been having some problems with it for the past 6 months or so. It is idling rough when I start it cold. After it warms up it idles fine. We have brought it in to Firestone when the service engine light came on the most recent time and the diagnostics test came up with 2 error codes: #171 & #174..... Below is a list of everything that we have done with it to try to fix the problem, but it still idles very rough from a cold start. I'm not sure where to go next on it. If anyone knows anything (reliable) about this problem or has a suggestion, please write back! thanks...
mass air control sensor replaced
idle control sensor replaced
pcv valve replaced
all 6 coils replaced
recent tune-up (all new spark plugs)
fuel, oil, air filters are good.
new transmission (6 months.)
Old Feb 26, 2007 | 10:10 PM
jimmythekid1's Avatar
Default RE: engine diagnostic test: error codes #171 & #174
I would check for vacuum leaks first, if you don't find any problems their I would check fuel pressure, I can'tgive you aspec of the top of my head because I don't work on a lot of fords.
The two I mentioned are the most likly to cause a lean code on both banks, but you may just want to find a reputable shop and pay them to look at it.
Old Feb 27, 2007 | 10:00 PM
babyhuey's Avatar
Definitely check carefully for vacuum leaks. Both codes are indicating adaptive fuel control lean limit has been reached. PCV hoses have been known to blow off and have seen several plastic intake manifolds that have warpedenough that the intake gaskets could no longer seal.
simmonsp5
Sep 21, 2023 04:49 PM
mccarvindh
Mar 14, 2013 09:18 AM
milehighProtege
Apr 13, 2012 09:01 AM
ravensoul567
Sep 5, 2008 04:18 PM
luchejko1
May 12, 2006 08:05 PM
