damp footwell 2001 tribute
Old Nov 13, 2011 | 11:54 AM
maxtherotti's Avatar
Default damp footwell 2001 tribute
Hi all
my 2001 tribute has got a damp drivers side (rhd car) footwell
anyone else had or heard of this problem and have any pointers of where to look before i start stripping the whole car down to fix it
Thanks Rob
Old Nov 13, 2011 | 04:08 PM
There are three usual things that cause this:
1) The heater box drain is clogged, missing or disconnected (A/C condensation.)
2) The drain holes in the bottom of the door(s) are clogged with filth, rust and debris.
3) The sunroof/moonroof drains are clogged and/or disconnected.
Beyond that I can think of any cowl drain that may be clogged allowing water to back up into the interior.
Old Nov 15, 2011 | 11:16 PM
Guyads's Avatar
Rear screen wash pipe could be leaking from in driver foot well.
It has a joint in there check this.
Old Jul 29, 2018 | 04:30 PM
slantnose's Avatar
If you have a moon roof it is most likely the drain line is clogged. There is one on each side that runs down thru the windshield post. If you have a compressor you can blow them out with about 100 psi from the top.
Old Jul 29, 2018 | 05:22 PM
peedee's Avatar
If you have had a front screen replaced i have had a leak from this and had to have it re installed as it was not sealed well enough
chinojuan
Jan 13, 2012 11:57 AM
cbole03
Apr 15, 2010 09:48 PM
seanlane
Aug 14, 2008 05:07 AM
Krol
Jan 27, 2008 07:40 PM
joverhol
Mar 7, 2006 11:39 AM
