Codes P0171 and P0174
Old Apr 23, 2010 | 07:36 AM
mmiller2002's Avatar
Default Codes P0171 and P0174
Our 2004 tribute with 100K miles recently started stumbling at idle while stopped at traffic lights. A few days later the CEL came on. The codes are P0171 and P0174.
Any ideas about the cause?
Thanks,
Mike
Old Apr 26, 2010 | 12:05 PM
falcaineer's Avatar
Your codes are very similar to eachother, and both mean an oxygen sensor detected a "lean condition" in both Banks, ie too much O2 in the exhaust. They could be the result of a dirty/faulty MAF sensor or a vacuum leak.
Some possible solutions are to clean the MAF sensor using an automotive electrical cleaner, inspect/replace vacuum and PCV hoses, or check for a dirty fuel filter and fuel pressure.
For more ideas, other posts on here refer to recently tuned-up Tributes showing these codes; you can run a search for "0171" and find them.
Old Apr 26, 2010 | 02:51 PM
fonda's Avatar
Default code 171
Check the air intake tube from the air cleaner to the throttle body. I have a protege 5 and the code came up 2 times. I felt the bottom of the air tube to find this cracked in the bellows area. I see others are having this problems as well. I haven't found an aftermarket so I duct taped and pvc taped over it for now.
Jack
azkev
Mar 11, 2012 10:00 PM
themcmullens
Mar 10, 2012 08:20 PM
cassincali
Nov 3, 2010 09:46 PM
cincy_mpv
May 10, 2008 07:52 PM
linebers
Jan 27, 2007 01:09 AM
