Check Engine ON - P0102 Fuel Air Metering Sensor
Old Jan 17, 2008 | 12:12 AM
ez's Avatar
ez
Default Check Engine ON - P0102 Fuel Air Metering Sensor
I got a Tribute 2001 3.0L V6. The check engine light is on. Checked and its P0102 - Fuel Air Metering sensor. I cleared it and it came back. Checked with the dealership and they mentioned the evap but I want to see if I can get more info here before I take it in.
How crucial is that and can I take care of it myself?
I appreciate any comments in that regard,
Aloha,
Eyal
Old Jan 17, 2008 | 04:40 PM
Default RE: Check Engine ON - P0102 Fuel Air Metering Sensor
Try CAREFULLY cleaning it w/rubbing alcoholand a well placed Q-tip.These things are very sensitive for something that rides around on wheels, so do not jar or rub is w/too much vigor.
What have you got to lose, right?
Old Jan 17, 2008 | 08:50 PM
ez's Avatar
ez
Thanks you for the info. Where do I find the fuel air metering sensor?
Old Jan 18, 2008 | 04:29 AM
On a Trib I'm not sure, but they are always found in the air intake system, often in or on the airbox, or possibly the hose that connects it to the throttle body. It's likely to have a wide, flat plug w/approx 7-10 connections on it.
Old Jan 21, 2008 | 12:29 PM
tribby05's Avatar
I have an 05' and the MAF is located on the air cleaner outlet tube , here is a pic hope it helps
luig
Feb 27, 2012 08:22 AM
nickvw
Sep 20, 2008 12:56 PM
rocweiller
Mar 11, 2008 11:09 PM
bryle
Dec 17, 2007 09:24 AM
Red00
Sep 11, 2007 06:35 AM
