2006 Mazda Tribute keyless entry
I have a 2006 Mazda Tribute s. The key fob will lock all doors, and will also unlock all doors, except for the driver side door. The same thing happens when I use the switch on the drivers door. I can’t find much about this issue online and would like to fix it so I don’t have to manually unlock it every time. Any ideas?
Sounds like issue I had, when I hit the lock button all but one locked. Found it was the door lock actuator which is a easy fix you can do yourself. Grabbed one from salvage yard and swapped out then issue solved.
2002 Mazda Tribute LX V6 3.0
Raes11
Mar 12, 2008 04:28 PM
