2005 Tribute 3.0L - Bad Motor Mount?
Old Jan 28, 2009 | 11:02 AM
SgtHulka's Avatar
Default 2005 Tribute 3.0L - Bad Motor Mount?
Just bought a used '05 with 70k on her. Once we had the front end tie arms and links replaced, I isolated a creaking/groaning noise on initial acceleration coming from the passenger side motor mount. After initial torque lessens, the creaking stops and the car is quiet during cruising.
The mount doesn't appear to be cracked or loose and does not appear to be damaged enough that I can see any motor movement.
Has anyone else seen/experienced this?
Is this a total mount replacement?
Any ideas as to cost should the dealer do it?
Thanks in advance.
Old Mar 27, 2012 | 06:06 PM
Ashley White's Avatar
Default Bad Motor Mount
Hi there, I know your post was a couple of years ago now but I just came across it tonight while dealing with the same issue.
I had a mechanic tell me this was the problem - the part is $400 new and about an hours worth of labour to replace.
Did you end up getting yours done? Did it solve the problem?
Bazooka
Aug 17, 2009 01:29 PM
klutch_3
Oct 18, 2008 07:58 AM
crackerjakx
Aug 27, 2007 01:43 PM
bigtuna
May 15, 2007 05:30 PM
sstlaure
Mar 28, 2007 03:51 PM
