2002 Mazda Tribute-Audio Question
I have a Tribute - ES-V6 with the factory 6 Disc, 7 speaker system. I've looking all over the internet for "how to" information on the correct specs for the speaker sizes. Mainly the sub in the back. Does anyone know what size it is, and if there is a small amp pushing the sub? I haven't attempted to check it out myself because of time, but I would like to replace the sub. I just want a little bit of knowledge as to what I'm going to be getting into when opening up the enclosure where the sub is.
Any help will be appreciated, or a reference link.
In my 2001 Mazda Tribute es V6 I have the same system and my stereo system has a subwoofer and it is a 8in round subwoofer powered by a amplifier that is bolted to the enclosure which is a morso plastic molded enclosure for the subwoofer on the right side when you open your back hatch I am looking up specs on the amplifier cuz I plan to replace the subwoofer and put a app that is about twice as strong till I pay off my car then I will be putting 4x 18 inch subwoofers in the back and all the specs will be to my likings. Hope that helped you mean while on replacing the subwoofer the panel on the back right should pop right off when you remove the panel or trim piece that goes across the back where the hatch latches so remove that first then start popping off the right panel to get to your subwoofer and then you will see the subwoofer with the grill that covers it along with a little grey amplifier.
