2001 Tribute
Old Dec 25, 2011 | 04:26 PM
Bobsyouruncle's Avatar
Default 2001 Tribute
What's involved in tightening the belts on the transmission of a 2001 Tribute?
Old Dec 28, 2011 | 02:57 AM
Manhattan's Avatar
There are no belts in your transmission to to tighten......If you are really having a transmission problem there are folks here that might be able to help you solve it....
Old Dec 31, 2011 | 07:30 AM
Default ???
No belts???? What was that that Mazda fixed on my Tribute when it was under warrenty when the trans was slipping?
Old Jan 2, 2012 | 11:10 AM
srfsteve's Avatar
The bands.
Old Jan 3, 2012 | 10:55 AM
Originally Posted by srfsteve
The bands.
What are we doing here, playing games?
Old Jan 4, 2012 | 07:40 AM
srfsteve's Avatar
No games, just trying to be succinct. Auto tranny's have bands that can wear and slip and tightening them may help. I never heard of belts in a tranny. Suggest you talk with experienced tranny mechanics to understand your options and risks. If yours is 4 cyl. and 2 wheel drive you might have less costs and issues to fix.
However, for my 2001 tribute es model tranny, to really fix the problem of severe slipping at 160K, would have required a complicated rebuild...much more than tightening the bands; For that tranny and engine combination the need for tranny rebuild is common. Some say its due to too small of a tranny for the power it transfers with the 6 cylinder engine, whereas for the 4 cylinder engine it works fine. A larger tranny would not fit in the restricted space on the 4 wheel drive model, so they compromised with this smaller less robust tranny. The extra power of the 6 cyl. causes excess heat and more rapid wear.
On the es model removal of the tranny is more difficult than for most cars, many shops charging $800 -1000 just for removal and installation, another $2000-3000 for the rebuild or replacement tranny.
For me the choice was a rebuilt one from autozone for $1600 plus installation and a 3 year waranty. It has been fine so far. I'm using synthetic fluid to help with the heat and wear issue.
Good luck
gav
Dec 16, 2021 03:10 PM
jeneenb
Nov 11, 2009 10:53 AM
wyciwug
Oct 17, 2007 07:56 PM
Spazm
Jan 22, 2007 10:30 AM
squeaky
Jan 26, 2006 09:49 AM
