engine problems galore!
Old May 22, 2005 | 10:30 PM
basil's Avatar
Default engine problems galore!
OK, is there anyone else out there with a 2004 RX8 manual trans. who has needed their engine replaced? I have only 20,000 miles on mine and suddenly the car started running lean, couldn't get any acceleration and the engine light came on. Took it into the dealer, they're stumped, called the main office and were told the solution was to replace the engine. Some kind of sensor (oxygen) was awry and they had new engines that had it fixed. Two weeks later I picked up the car (under warranty, thank god!) and drove it for ONE DAY before the same thing happened again, engine light on, and couldn't accelerate over 10 mph. Had to have it towed in and am now waiting to hear the verdict. This stinks. Up to now I loved the car.
Old May 23, 2005 | 12:11 AM
tpbaker's Avatar
Default RE: engine problems galore!
oh CRAP my 2004 has 28200 miles and the engine light came on yesterday! It seems to be running fine. I hope this is not the start of something awful!
Old May 23, 2005 | 07:37 PM
stilltryin's Avatar
Mine has 13,500 on it. Only thing so far is oil light came on, I pulled over immediately, was still full of oil, light went off and has not come back on since, figured it was just a fluke. Will definately watch the engine light!
Old Jun 16, 2005 | 03:14 AM
TheRedBaron's Avatar
I have an 04 Rx-8 and I had my engine light come on around 6,00 miles. It was sputtering through first and second gear around 4,500 rpm's. I took it to my dealer, and the computer was going nutty. It turns out that it was misfiring one of the plugs. They told me they re-programmed the computer with an upgraded software, and it has been fine ever since. Try giving this a shot.
Old Jul 15, 2005 | 04:45 PM
khblair's Avatar
all of these seem to be with with 2004s. does anyone know if this problem was fixed with the 2005 models? we just brought home the Shinka this week and this makes me very nervous!
Old Jul 28, 2005 | 08:58 PM
babyhuey's Avatar
There have not been many engine problems outside of vehicles with auto trans. There are some issues with compression that are being looked into. As for your low oil light coming on with level being ok. On 2004 model only, if the last six digits of your VIN are at or below 111043 there may be an updated oil pan and pcm reprogram available to correct this. Check with you local dealer. If you are not experiencing this problem then don't worry about it. Not all are affected
Old Aug 3, 2005 | 05:33 PM
wuboog36's Avatar
Don't feel too bad, my 2004 automatic rx-8 has had the engine replaced, another oil cooler added, and then the same thing; a car that shuts off when it comes to a stop!! Haven't had it for three weeks and still do not know what they are trying to do. I agree, loved the damn thing until now!
Old Aug 25, 2005 | 05:49 PM
the_gray_mazda6's Avatar
cars like to play guessing games with you. i had a 96 ford explorer, was taking an offramp and it turned off on me midway through a turn at the bottom of the ramp and i almost nailed it. lost all hydraulic power as well.
Old Aug 26, 2005 | 07:10 PM
MAZDASERVICE's Avatar
There is an updated pcm reflash for this concern...have your dealer look for the T.S.B
Old Aug 26, 2005 | 07:13 PM
Default OIL CONSUMPTION
OIL CONSUMPTION
This is normal for this vehicle.
IF you all read your manual..your RX8 will use oil...advise to check it every 500km-if your heavy on the pedal it will use more oil
