Over heating??
Old Jun 22, 2006 | 05:49 PM
87 turbo II's Avatar
Default RE: Over heating??
ORIGINAL: 1FAST7
Sounds like the coolant seals are shot. If they are, time for a rebuild.
No coolant burns white and if the seals were shot they would go direcly from the waterjacket into the combustion chamber, or exhaust system and there would be white smoke everywhere.
Old Jun 22, 2006 | 11:41 PM
1FAST7's Avatar
But he did say that it was pushing out the overflow bottle. Sign of bad seals, bad thermostat, or a blockage somewhere. Just to narrow it down.
Old Jun 23, 2006 | 06:32 PM
babyhuey's Avatar
How fast does the cooling system develop pressure or upper radiator hose gets very hard? Should take several minutes for the coolant to get hot enough to expand and create pressure. If it building up very quickly then would def suspect leakage between combustion chamber and cooling system. Leave the radiator cap off and start up engine. If coolant gushes out of the open cap then is a good indicator.
Easy enough to see if the coolant is making its way into the combustion chambers. Warm it up so there is pressure in the system or pressurize with a testing tool. Take out the Leading or lower two spark plugs and then roll the engine over backwards or counterclockwise. Any steam or water coming out of the plug holes would point to breach between coolant passage and combustion chamber. Most common problem I ever see for this happening is running straight water in the cooling system. Electrolysis develops with only using water and no coolant which actually eats a hole thru the aluminum rotor housing, most commonly near the leading spark plugs.
Old Aug 1, 2007 | 01:19 AM
ElTico7213's Avatar
check ur coolant and ur oil gotta b cahnged more freuquently b/c of the turbo. an oil cooler would also help...but also u gotta know that rotary engines heat up quickly also...
patchshorts
Dec 23, 2011 10:13 PM
iloveemymazda
Sep 3, 2010 08:31 PM
joshrichy
May 20, 2009 07:37 PM
clow357
Oct 6, 2006 11:32 PM
moochie44
Nov 26, 2005 11:35 PM
